The fourth generation Nissan Altima (chassis model L32A) was announced at the 2006 New York Auto Show on April 12, 2006. It was the first vehicle to use the smaller Nissan D platform, with a new front and upgraded rear suspension.
Why cooling fan runs and engine won't start?
My car was running normally then switched off the engine for a few hours, came back and while trying to start again, cooling fan runs, no crank and engine won't start.
All dashboard lights on after single click on start button while pushing breaks (cooling fan runs), which is really weird coz engine is not hot. Another press on start button, everything goes off.
I recently changed radiator and spark plugs + 2 ignition coil.
Any idea what could be the reason and how i can fix it?
crwdns2944067:05crwdne2944067:0
We’re is the bcm I’m having the same Problem
And what all I have to tske off my part car with the same year 2007 to get this one running
Help....I am having this same issue. What did you do to fix it?
In my skoda fabia it was immobiliser. I just had to disconnect accu (battery) for 1 minute, then reconnect and engine started:)
I have the same problem but I have a '94 BMW 3 series
crwdns2933315:07crwdne2933315:0
It may well be that the fault with the cooling fans has drained the battery too much, when it tries to start the battery voltage collapses and the electronics give up. Try charging the battery or use a booster pack to get it started, you can then drive it somewhere to get the cooling fan problem fixed - this may well need to be a main dealer with the right diagnostics equipment.
Try to change coolant temperature sensors.the sensor send wrong information to ecu.when ecu located engine temperature high,ecu send signal to cooling fan for running.and when engine hot it not start
Mine did the same and it was the engine control fuse. It's in the fuse box under the
Under the what? I cant see the rest of the text
Hood I think .
This usually an indication you have a shot BCM.
Where ia this located?
BCM? What is that?
I’m have this problem now . The guy look at it he put a used relay on my van and now the same thing is happening. I’m going to buy a new relay and get the battery charged and see what happens.
Did you find out what it was?
It might be immobiliser. I disconnected battery for 1 min, reconnected it and the car started
Anyone know why the headlights, blower motor and turn signals are all on at once without the car started?
You might have a ghost in that cat!!!loli had battery and alternater checked out and they are good. Relay is what I’m thinking.
I had the same problem with my push button start 2009 nissan altima. I changed out the cooling sensor, ipdm and cooling fan relay, no help. What i found was the brake pedal switches had moved out of adjustment. I set the switch to correct settings and it started right up. Too bad I didn't try that first.
Ahmad Nawar crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 65
crwdns2936753:030crwdne2936753:0 282
crwdns2942667:0crwdne2942667:0 28,171
