Learn about the skills that you might need to work on your device.
crwdns2934591:087crwdne2934591:0 crwdns2934593:0crwdne2934593:0
How to use an engraver on stripped screw?
Hi all,
I have started to attempt to repair things as a hobby and strip some screws from time to time.
Unfortunately one screw has stripped completely on a pair of beats I was working on I tried the rubber band and glue method to no avail.
I am awaiting a delivery of an engraver as I read on here some people have had success with these.
Does anyone have any experience with using an engraver to fix a stripped screw how did it go?
Any videos to share of one being used?
Thanks
crwdns2942205:01crwdne2942205:0
Are you talking about a Dremel?
Never heard of using a Hand Engraver to take a screw out.
I often use a left hand drill or a screw extractor like these Precision Screw Extractor Set to remove smaller screws used in computers. I also find using a soldering iron to heat the screw up can also help to soften thread lock.
The last option is cutting the screw giving it a slot using a Dremel tool and a thin cutting wheel. Is that what you mean by an engraver?
crwdns2886500:0Precision Screw Extractor Setcrwdne2886500:0
crwdns2934075:0crwdne2934075:0
$24.99
crwdns2942205:01crwdne2942205:0:
Thank you for sharing your detailed response I have purchased the recommended extractor set and will give those a try when they arrive.
Joe Richardson crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 322
