The Samsung Galaxy S9 is identified by its model number: SM-G960XU. It is the ninth generation of Samsung's Galaxy Series that was released in March 2018. Available in Lilac Purple, Midnight Black, and Coral Blue.
White circle lightning , doesn't charge, diagnostic steps
Hello,
I am trying to save a S9, my company doesen’t need it (no warranty).
If I plug the phone I get a white circle with lightning icon, nothing change after an hour.
Bought another battery, nothing changed.
The phone turns on by itself, if not plugged. Phone vibrates, Samsung Galaxy logo appears and nothing happens.
No signs of burned, missing or water damaged components.
I have laboratory power Supply, microscope, multi meter and experience with notebook repair.
Can you suggest me any diagnostic steps?
crwdns2944067:07crwdne2944067:0:
Can you post a picture of this white circle you're talking about? And where did you buy the battery from?
Could be a few things wrong with the device but i would test all major battery/power areas first have you tried to wirelessly charge the device to see it was battery or maybe even charge port?
https://i.imgur.com/eUkr01t.jpg
I have no wireless charger, the second battery was charged when it arrived.
I am going to buy "hot air station" and remove the shield. Have no idea yet what and how to measure.
I am having the same problem with my Samsung also.
What is the problem when my phone goes around in circles while charging
crwdns2934275:02crwdne2934275:0
If the phone does not boot with a known good battery, it is likely a motherboard issue. If you’re experienced with microsoldering it may be worth the effort, otherwise I would invest in a new phone or send it off to a professional! Also, just to be sure, I would disconnect the power button cable and try booting it up. Sometimes a faulty cable will cause boot issues.
I held down power button and then pressed volume up button and phone came back to normal.
I just did the same thing and it worked.
I held down power and up volume button, went into reboot mode then the white android with the yellow triangle was stuck in the middle of my screen with the words no command
sibbirius crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 177
crwdns2942667:0crwdne2942667:0 21,009
