Samsung's tenth flagship Galaxy phone, released in March of 2019. Shipped with Android 9.0 (Pie).
Why Samsung S10 won't detect my SD card?
I’ve been using the microSD card on Samsung S10 from the past few months and it was working correctly until today I saw, my phone isn’t showing SD card. what should I do?
Hi @angelojoy ,
Did you try turning off the phone and then restarting it to see whether the card was now being detected, you didn't say?
Did you try correctly removing the SD Card and then reinserting it to see if it being detected?
Can you try another SD Card to see whether it is being detected at all?
Has the phone been dropped or gotten wet at all?
What have you tried?
I've tried all the solutions listed in this article, (https://www.seektogeek.com/sd-card-not-d...), but none of them worked becuase the SD Card itself is corrupted or maybe damaged. Because after inserting new SD card, it is working perfectly like before...
Hi @angelojoy ,
The article did have a solution that worked - Solution 9: Buy a new SD Card - as I also suggested - "Can you try another SD Card...?"
@jayeff yes..and now it is working correctly!
Bought new micro SD cards from SanDisk directly. Only the 16Gb would work for 1 week before the tablet would post the "SD card error". What is noticeable is the OS does not overwrite files but deletes them. After editing a file, then replacing the file on the tablet, if you go to "trash" the overwritten files will be in "trash".
angelo crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,753
