Hi,
I couldn’t find any information about your coffee maker and I’m not a circuit designer but I think that this MOV -example only would suffice.
It has an AC cutoff rating of 150VAC which is about 20% higher (which is usually what is specified for MOVs) than the supply voltage of 120VAC. It also has a current rating of 25A so if it does operate to suppress any surges it will be able to handle enough current for a short while anyway before it fails. Your machine only uses 15A but I thought that getting a MOV with a current value of 15A was cutting it a bit fine and the next value is 25A.
Unfortunately I cannot find a supplier that supplies less than 5 pieces. You may have better luck. Alternatively go to your local electronics parts store (or electrical parts store) and ask for a MOV that has the specifications of 150VAC, 200VDC and 25A and that will fit on the board.
Also be aware that there may be more problems with your coffee maker. Hopefully the MOV did its’ job and operated before any damage was done to the other components on the board and not after.
I guess that you will find out.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
0
Hi,
What are the voltage (V) and power (W) specifications as printed on the model label on the machine?
This will help to determine what value MOV is required.
What is the full "board" number of the board in your pictures? I can only make out 2628 Rev A.
Maybe searching for the "board number" online may give results. Worth a try anyway.
Also hopefully you meant a 220V -110V converter?
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
Thanks. The spec of the model is 120V 60Hz and 1470W
The board number is PT0000002628 REV A . Which unfortunately I can not Google out anything.
Yes the converter is 220-110.
crwdns2934271:0crwdnd2934271:0 chai chaiqinglink crwdne2934271:0
Hi I have exactly the same problem, do you solve it ? only by the MOV ?
You don't know if it has a fuse as well?
crwdns2934271:0crwdnd2934271:0 mariofl82 crwdne2934271:0
