The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
crwdns2934591:01185crwdne2934591:0 crwdns2934593:0crwdne2934593:0
One screw just came out and won't screw
The other day I heard something falling and I noticed it was a screw from the bottom of my macbook, and when I tried to screw it, it rotates, however it will not hold… This is weird because nothing happened to my computer… What should I do?
It seems like maybe the screw mount has failed on you where the screw usually seats to hold the back cover on. I have had luck using a small amount of hot glue on the underside of the screw applied with a toothpick, simply to plug that hole and avoid dust and other particulate having easier access to the inside of the case. Otherwise, if all your other screws are intact, it should not be much of an issue for you. This is intended to be a cheap and quick fix though, and if it concerns you a lot, other solutions may be required. In the case of an apple laptop… replace the chassis?
kraki crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 74
