Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Won't charge after new battery
Replaced battery that customer thought battery was dying and iPad mini was fine. I had lock screen with home picture and pin came up so I knew it was good to go. I plugged it in and went to bed. Next day I went to check it so I could deliver it and it had not charged at all. I can plug it in (with OEM cable and block) and I get the flashing low battery and lightning symbol but it never charges. Thoughts?
try to clean the dock connector with some IPA spray because it’s fake charging now , it shows that it’s charging but doesn’t take no power . If it’s still not working you will need to replace this sparepart , but you will need some soldering skills :) iPad mini 2 & mini 3 Lightning Connector
crwdns2886500:0Replace a lightning connector compatible with the 2nd or 3rd generation iPad mini. Fix problems with charging or USB device connectivity. Installation requires micro-soldering.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$19.99
crwdns2889612:0crwdne2889612:0 -1
goldenkenneth crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 164
