Dryer won't turn off.
The setting dial keeps going around without stopping. I replaced the timer switch already. The dryer heats as normal. The dryer will only shut off if I open the door or unplug it. It goes through all the settings.
@astro19 what is your dryers complete model number?
It's a 70 series. #97374210
Hi @astro19 ,
Does the dryer start straight away when you plug in the power?
Yes. Also as soon as I shut the door.
Hi @astro19 ,
Have you checked that the start switch is OK and not permanently operated?
Disconnect the power and use an Ohmmeter to check if it is OK or short circuit perhaps
