Hi @freddie1957
Does it show that it is charging when you connect the camera to a computer’s USB port?
If so then the charging adapter is faulty.
If not, visually inspect the camera’s USB port using a magnifying glass and a strong light. Check that all the pins (5) are there and that they are straight and parallel with each other and are not bent or broken off.
Also check that there is no debris in the port enclosure which may prevent a good electrical connection. If there is DO NOT use a metal pin or probe to try and get it out. Use a vacuum cleaner to try and suck it out. If it won’t move, use a sharpened wooden toothpick to gently, stress gently try and prise it out. You don’t want to damage the pins
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
