The Kia Optima is a mid-size car produced by Kia Motors beginning in 2000 and marketed globally with various names. Firsts-generation cars (2001-2005) were generally sold as the Optima, though the name Kia Magentis was used in Europe and Canada when sales in those regions began in 2002.
My door won't open
My driver's side door is shut and will not open. How do I get the door panel off?
It does not open with the outside or the inside door handle? Does your lock work? Do you have power lock's?
our car is having the same problem. local mechanic cannot fix until he gets door panel off which he cannot do because door won't open. Locks work fine. any suggestions???? will not open from inside or outside
Check on here and look for an answer by ekubec. Here is a further link that gives you more details as well as pictures. Hope this helps, good luck.
hello:
Simply order a new door latch assembly for the door with problem (mostly drivers side door) thru ebay, Amazon or Partsgeek and have them deliver to you ( about $55 delivered), take to an auto service shop and they will install that for $65. After that it will work great. Door problems are due to wear and tear and latch assemblies fail and need replacement. This is a maintenance problem, like changing water pump or any other part of the car. I don't think any other way of fixing will work.
Kumar
chadda crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 7,224
