MacBook Pro 2017 not coming up after not being used for sometime
Hello,
I have left my MacBook Pro for more than a month now without using it. Now when I try to power it up, it won’t come up. Any advice on what to do or what the issue might be?
EDIT:
Here is the screenshot after installing CoconutBattery. Does it seem that there is any issue with my battery?
Can you tell us what is your exact model 13" or 15"?
crwdns2934271:0crwdnd2934271:0 Dan crwdne2934271:0
It's a 13-inch Macbook Pro
crwdns2934271:0crwdnd2934271:0 gideon onwuka crwdne2934271:0
Well, the good news the battery is still OK! But you are running your system hard! You have quite a few cycles for such a young system. You should get into the habit of not letting the battery run down so far before charging. When you run down below 30% you will likely push a cycle which will add up to the point you'll need a new battery.
I'm wondering if one of your ports is damaged which is why you had a problem charging the system before. I think it would make sense getting the power meter to check if you have a bad port. As it turns out the port assembly is easy to replace.
