The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
Why won't my Xbox power on?
Well, after a power surge while I was away from home, my Xbox wouldn't power on. I knew it was the power supply because it's meant to do that, to protect the other components. But, even after buying a new one off this website for $20, I have replaced the power supply and it still won't turn on. I followed each step by step and finished. But it just won't power on. I've tried the socket, yes it works, the cable doesn't appear damage (plus I used another one to test), but the console won't make any noise or power up whatsoever. What do I do?
Sounds like a blown VRM (Voltage Regulator Modules) circuit on the board. There are components on the board that make up that circuit to power the logic board. That'll require some circuit level troubleshooting and microsoldering to fix.
For this I think getting another Xbox One S would be the cheaper and option (at least for 2nd hand).
That's what I didn't want to hear
If your Xbox Won’t turn on then it might be battery, adapter, or power supply Problem. Therefore, Check one by one for finding the real cause. Otherwise, You have to replace your Xbox.
Jorge Ambriz crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 2,255
