Can the backlight ribbon be replaced on the Mid2014 MacBook Pro Retina
A long time ago, I had a white Macbook malfunction such that the backlight would flicker on and off randomly and for random periods of time before eventually failing to work at all. I replaced the backlight “ribbon” connection to the logic board and it worked perfectly. My Mid-2014 Macbook Pro Retina experienced exactly the same symptoms and I was wondering if it is possible to replace the ribbon assembly on this model? From an initial inspection, it seems like the display is assembled in a much less forgiving way for repairs, as the there is no physical trim holding the screen in place and all the aspects of the screen assembly seem permanently coupled.
