MacBook A1534 2015 Logicboard Swap to 2016
Hi there,
I have a MacBook 12” A1534 (2015) with an broken Logicboard (BAD CPU). I bought a Logicboard from am 2016 MacBook 12” für just 250 Euro. YEAH!
I have built it in. All cables except the USB-C Flex fits front the 2015 into the 2016 Logicboard.
But the battery LED is not lighting up. Is the 2015 battery not compatible with the 2016/2017 Board ?
Are all other Components compatible ? or I need to change also other parts ?
I have ordered now a new Battery, new TrackPad, new USB-C Flex and a new IPD Flex. The rest should be compatible.
But still cheaper than a Logic Board swap from Apple or a 2016 MacBook12“
more than likely it will not work with an older battery, the system will not recognize it
They use different batteries. The 2016 uses this one:
MacBook 12" Retina (Early 2016-2017) Battery
The 2015 uses this one:
MacBook 12" Retina (Early 2015) Battery
crwdns2886500:0Replacement 4800 mAh battery for MacBook 12" Retina (Early 2015).crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$109.99
crwdns2886500:0Replace a 4800 mAh battery compatible with MacBook 12" Retina (Early 2016-2017). 36.2 Watt Hours (Wh), 7.55 Volts (V).crwdne2886500:0
$109.99
Hey Guys,
I am finished!
As described, the old MacBook Battery from the 2015 Modell works perfectly with my new Logic Board.
The USB-C Flex doesn’t fits into the 2015 Topcase. With a multi-function tool, I had to remove a bit on the inside of the Topcase near the USB-C Port. Now the new USB-C Flex fits into the “old” Topcase but the Screws was to long. I have replaced it with two Screws from an old & broken iPad mini. Hold like out of the factory.
The new Trackpad works (sure) perfectly. I don’t have tested the 2015 Trackpad.
Did you succeed in replacing the 2016 version logic board in the MacBook 12-inch 2015 version housing, battery, and LCD? Or did you end up replacing the battery as well?
If you read the explanations of the parts sold, only IO Cable and logic board are divided into 2015 or 2016 (2017), and the rest of the cables, LCDs, and batteries are compatible, so I wonder how to purchase them.
(I want to replace 2015's logic board with 2017)
Hello. I have a 12” macbook 2015. What would i need to do to upgrade it to 2017. If the 2016 works as you said should it be same for 2017? Can you give me some more details abot the swap.
golffreiburg crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,121
