Arne Büsing without knowing the actual panel number and only going by the information you gave us it looks like it is compatible with the following:
MacBook Pro 15.4" 2.0GHz Core i7 (A1286) - Early 2011
MacBook Pro 15.4" 2.2GHz Core i7 (A1286) - Late 2011
MacBook Pro 15.4" 2.4GHz Core 2 Duo (A1286) - Late 2008
MacBook Pro 15.4" 2.4GHz Core i5 (A1286) - Early 2010
MacBook Pro 15.4" 2.53GHz Core 2 Duo (A1286) - Mid 2009
Your panel should be one of these models
LP154WP3, LP154WP4, LP154WE3-TLA1 or LP154WE3-TLB1 if so, it’ll fit.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
3
crwdns2944067:04crwdne2944067:0
Your systems specs: 13" MacBook Pro 2.53 GHz Core 2 Duo (with SD slot)
crwdns2934271:0crwdnd2934271:0 Dan crwdne2934271:0
Are you up to replacing the LCD panel alone? Or do you need to replace the full display assembly (case damage).
I was planning to replace the full assembly. I don't have the tools to remove the glass, so buying a used assembly is the cheaper choice.
crwdns2934271:0crwdnd2934271:0 Arne Büsing crwdne2934271:0
Then you'll need the correct assembly part as there is enough differences in the part to prevent the substitution of the full assembly.
