The Anywhere Mouse MX is a laser mouse released by Logitech in 2009. The mouse connects via a Logitech Unifying receiver and is powered by two AA batteries.
Power Switch Doesn't seem to keep the mouse powered on
I've had my Anywhere Mouse MX for ages. It keeps working even after some nasty drops. But, now there seems to be an issue where the power slider doesn't seem to press down on the little power switch under the case fully. What ends up happening is when moving the mouse on any surface, it seems to move that switch ever so slightly past the point of pressing it down fully to keep it turned on. What it looks like on the screen is that the mouse is lagging all the way across the screen, when in reality it's just the power flickering from the switch not fully pressing down the power flicker. Can I add anything onto either the moving or the static piece to try and keep it held down better? Or should I take the mouse apart and diagnose the issue further from there? I've already fiddled with trying to bend the sliding piece up a bit more, but it doesn't seem to help for long as it's all pretty tough material.
Perhaps add something small and skinny, and sticky (such as a small pice of double stick tape between the sliding plastic piece and the base of time mouse? It will have the effect of making it harder to turn on the mouse, but may solve your problem. Only other thing that comes to mind is using a piece of scotch or similar tape to (semi)permanently attach the power trigger button to the inside base of the mouse. Up to you how strong you want to go with the adhesives of course!
-Mike
Kyle Stengl crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 624
