Model A1040 / 10, 15, 20, 30, or 40 GB hard drive / four touch-sensitive LED backlit buttons above touch wheel
Battery Replaced, Recognized by Computer, Won't Charge?
I just replaced the battery with an iFixit (super easy!) and the iPod started right up. It is showing little to no battery power. When I connect it to by Macbook, iTunes recognizes it, but it does not charge. I’ve tried multiple chargers with the 30-pin cable (brand new) and I can’t get the lightning bolt to come up.
The only suggestions I’ve seen are related to replacing the battery, which is what I just did. I went back, disconnected the (new) battery and reinstalled it, still the same issue.
It’s FireWire…isn’t it? I’m not using FireWire to charge…
To clarify, when you said, "The only suggestions I’ve seen are related to replacing the battery, which is what I just did. I went back, disconnected the (new) battery and reinstalled it, still the same issue." does this mean that you disconnected and reconnected the NEW battery, or you disconnected the new battery and reconnected the OLD battery? I'm curious to see if the iPod will charge on the old battery.
Your problem is the connection. The iPod 3rd Gen does not charge through USB but needs Firewire connection. This model only syncs through USB. Hope this helps, good luck.
You need a FireWire cable and power adapter to charge it.
Cable: https://www.ebay.com/sch/i.html?_from=R4...
Power adapter: https://www.ebay.com/sch/i.html?_from=R4...
Note: Some eBay listings already include both things in them, since they are used together.
Ryan Harris crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 70
