Repair guides and support for the 5th generation Honda Civic, first released in late 1991.
My car was idling then stopped and won't start up again.
My (95) car started up first time every time. I like to warm it up a minute or so before driving. While I was idling the engine just stopped, as if I turned off the key and won't start up again. Fuel filter is fine, battery is good. I'm stumped.
crwdns2944067:04crwdne2944067:0
Does it turn over at all or do you get nothing when you turn the key? Any lights on your dashboard? Do you know the engine size? How many miles?
GReat that you got it fixed :-) just copy your comment as an answer and teh accept it. That way we know it has been resolved and people can look at your solution and know it worked. Good Luck
I moved it to an answer and accepted it. :)
Thanks....:-)
It turned out to be the distributor. Thank you for the response.
How did you find out?
Their is no answer on here for what the problem is??
Tyrone, look at Peggy's answer. That was her problem. Should you experience similar issues, do ask your own question. Click on the link on the right side of this page "Ask a question" and give as much detail as possible, good Luck.
I had a similar problem.
It turned out that the need to solder fuel pump relay. I do not remember how it is properly called, but it is to the left under the dashboard on the driver's side. Search for MAIN RELAY (if i right).
Just open and solder all contacts.
My 95 ford thunderbird starts but when you turn it off it wont start
Peggy crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 14,774
