Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
Screen won't close tight after display replacement
I replaced new display for iPhone 7 by LCD Screen and Digitizer Full Assembly Fix Kit and I have no problem during repairing steps where I applied new display adhesive.
Now I have problem when I close device that is a gap between the display and rear case, exactly on bottom right corne and on half bottom of right side.
What do yo suggest me ?
I found out problem! It’s problem with new display, I tried to assembly again the old display and It closes tight.
There is IC cent to display flat and It’s not aligned, infact bump into metal shield of rear case.
Hi
Perhaps your phone frame is bent, because of this skew the screen does not sit tight to the frame
I have the same problem for mine, and I think it might be that the battery bracket may be pushing up on the screen. My battery bracket was popping up on one side while the other was screwed down and I had trouble screwing both of the the tiny screws in without one popping out. This causes the entire battery bracket to sit at and upward angle and apply pressure on to my screen. This may not be your exact problem but it is worth a try to see if that could be it.
it will be the small rectangular heatshield on the back of the new screen not alignet correctly, there is a recess on the loud speaker it has to sit in.
strange thing is the old lcd sits down correctly, what do you think? It's design flaw?
I tried everything on mine and it ended up being that the back was slightly bent. I bent it back into shape gently and resolved the issue.
omg i had the exact problem and thank you i wouldnt think the frame would be bent now i know the actual reason
Riccardo crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,094
