The OnePlus 5 (OP5) is a 5th generation smartphone released June 20, 2017. It is the successor to the OnePlus 3T and predecessor to the OnePlus 5T.
Screen doesn't work after dropping mug on rigt top corner of screen
My phone still partially works as I can hear notifications coming through, shutter noise when I turn it on, alarm still goes of and tapping noises when I touch the screen were buttons would be however at first there was just coloured blocks on my screen when I turned it on but now there is noting just black. I think there is a problem with connection between screen and motherboard-how do I fix it and how much is it likely to cost?
If you truly believe it’s just a connection issue, try disconnecting your screen and reseating it. If this fails, you more than likely are going to need to replace your screen. The reseating will be free as long as you don’t break anything, but a new screen will probably be just shy of a hundred dollars. Heres the screen replacement (with frame):
OnePlus 5 Screen and Digitizer Assembly Replacement
the part:
OnePlus 5 Screen
crwdns2886500:0Replace a front glass digitizer screen assembly compatible with the OnePlus 5 smartphone. Features a 5.5 inch 1920 x 1080 pixel AMOLED Display. Includes the front plastic frame.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
OnePlus 5 Screen
$79.99
Sophie MacDonald crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 242
