Infinix Mobile is a Chinese entry level smartphone company founded in 2013.
INFINIX X559C(hot 5 ) don't display after screen replacement
hi
My phone: infinix x559c (hot 5) fail to display after screen replacement.
The initial(old) screen got spots yet it partially displays, on replacing with the new screnS, it don’t work.
After testing with the new screen, the old screen also no longer display at all again.
It see PC when connected via USB, vibrate when charged. Have tried several new screen and some other battery as well.
BUT IT DON’T DISPLAY AND WON’T RESPOND WHEN TRIED TO POWER ON WITH BATTERY.
KINDLY HELP, THANKS IN ADVANCE
My haven't spoiled you can here sounds but it can't display
The screen display diodes have a problem. You need to get an exact replica of the phone and change the diodes
Try to format the phone first
SO If it's doesn't work then try to turn it on with the power flex but use the the port go do so
If it doesn't respond then service the panel
And if doesn't work, the it's the display ic
I think this is only way to troubleshoot it
nath crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 471
