Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
crwdns2934591:0872crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Why is my iPhone stuck in a boot loop after screen replacement
This question hasn three parts:Okay….so after buying my step sister a new phone screen and installing it my self the logic board sparked, but before it sparked it was stuck in an infinite boot loop, any answers
second part: after the replacement the screen has lines going down the screen, any answers
third part: when I tried to fix the first and second part, I conneced the phone to iTunes and put it into recovery mode, but when I hit restore and let it restore the phone to factory settings, the phone was still experiencing the issues in the first and second, forgot to mention that when I installed a new home button, the new home button didn’t work…any answers
Iphone 7 and new ios device have the new parody that The original home button that present on the phone at first is the solution for long boot loop.Check out if the problem of home button flex phone boot up after 5-6 minutes and working fine or Audio Ic problem.If the short bootloops that is the problem of baseband chip or bbpmu.
Any way changing home button is not the solution for that.
crwdns2942205:01crwdne2942205:0:
So...are you saying I should buy a new home button bracket and a genuine apple home button
Well, the screen may just be a non-quality part so I would advise you to return the screen and buy the screen from iFixit instead. iFixit only sources parts from trusted vendors who produce higher quality parts and iFixit also rigorously tests their parts too so there is less of a chance of part failure.
If the Logic Board did spark, you probably fried the Logic Board. I would give a new Logic Board a try and see if the boot loop goes away.
iPhone 8 Screen from iFixit
crwdns2886500:0iPhone 8 Screencrwdne2886500:0
crwdns2934075:0crwdne2934075:0
iPhone 8 Screen
$54.99
Do you know where I can buy a genuine apple screen other than ifixit (to expensive from ifixit)
@seanmoss I do not recommend anywhere else because the "cheaper parts" tend to be either the scams or the defective ones. As of right now I do not know anywhere else I can get you a quality screen replacement for less money.
Hello, I disconnect the front proximity sensor, the only downfall is that you lose the selfie camera function, but I would rather that, than no phone at all.
Sean moss crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 1,368
