Won't boot up bad I/O board?
My MacBook Pro has a bad battery connector possibly. Thats what I initially suspected and hoped for. Or, it could be bad I/O board or bad logic board.
It was working fine when I shut it off one day. I came back some days later and it just wouldn’t power on again. It has a newer battery and charging cord. The thing lights up when I attach the cord.
The first pin on the battery connector has no continuity but the rest of them do. I did leave it plugged in constantly when it was working. I’m wondering if I burned something out in the battery connector. A new one is cheap but I got discouraged after someone I asked on this website said that it was likely a logic board problem and supposedly my system had that type of failure frequently.
It’s a MacBook Pro 15" non-unibody model A 1211.
I could try replacing the battery connector if it might help.
What do you think? might it be worth trying?
I spun your MacBook Question out so others could offer their viewpoints.
thank you dan.
@mayer - any ideas?
I changed the icon to the machine you said you have.
Let’s get some information first:
Here is the pin out for the Mag-Safe:
Pin 1GND (0 V)
Pin 2V+ (14.5 / 16.5 / 18.5 / 20 V DC)
Pin 3Charge control pin
Pin 4V+ (14.5 / 16.5 / 18.5 / 20 V DC)
Pin 5GND (0 V)
What is the wattage of your Mag-Safe? What are your readouts?
When you plug it in what color is it and does it change within 10 seconds?
Try an SMC reset:
Connect the power adapter to the Mac. On the MacBook / Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time. Release all keys and the power button at the same time – the little light on the MagSafe adapter may change colors briefly to indicate the SMC has reset.
i have already tried the smc reset i have tried replacing the tiny internal battery i have tried removing the cord and battery then holding down the power button to clear static build up . its a 15 inch non unibody macbook pro model A1121 the charger says it puts out 18.5 v 85 w.
I am not able to test with the dmm until tomorrow most likely but i appreciate the info on the pins. I will get back to you on that asap. i have a part to get from tractor supply before it closes. thanks.
Jessica Steiner crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 191
