Whirlpool Quiet Partner III won't drain
I just reinstalled my dishwasher after it had been stored for a few years in my unheated garage.  The water inlet valve was cracked (big surprise) so I replaced it.  Now when I ran a test cycle, the water is not draining from the dishwasher.
HI:
Could be your drain pump is bad. But sitting for a year also the filter, grinder and area could be full of debris. Here is a great site to give you ideas on how to fix your washer, As you look for a part and click on the part picture you get a video on how to replace this part, but then you can see how the unit is put together and clean your unit out. Or replace parts not working. I am guessing a stuck flap valve also could be stuck closed.
https://www.partselect.ca/Models/GU1100X...
Good luck.
Alton
crwdns2886500:0Pumps water out of your dishwasher during the drain cycle.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
Whirlpool Dishwasher Drain Pump - WP661658
$61.99
Turns out the drain pump motor was bad.  Cleaned up the filter, grinder and flap valve.  So far, so good.  Thanks!
Lee Best crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,363
