Repair guides for the Kenmore 80 Series of washing machines, manufactured by Kenmore.
won't drain water or spin
won't spin or drain water out
Cause 1
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
Cause 2
Motor Coupling
The motor coupling connects the motor to the washing machine transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Cause 3
Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
I have a similar issue. The 80 series is by direct drive transmission. Thus, no drive belt. However, just above the transmission, there is a belt around what would be a bearing assembly. This belt is loose on mine and I dont know if it has much to do with hi spin, but I see no other problems.
marthalaytonpierce crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 2,441
