Phone was thrown and now display won't stay on
My ex had thrown my phone it hit the wall and it bent up the top left corner. there's minor separation between the front part of the phone and the back part . the phone works fine after that the only thing is I had to swipe it quick to unlock it because it would time out real fast on the unlock screen. I had no problems with the display or the touch screen whatsoever. then out of nowhere the lock screen was timing out even faster that it would just flash on and go off I don't have time to swipe to unlock it. the phone vibrates when I'm hitting the power button and trying to swipe it real quick so I know the touchscreen still works. I'm trying to figure out what the issue is with it and what I would do to fix it I'm not sure if maybe it's a connection problem or if it's the backlight. I have a second droid turbo phone that I can use for parts. the phone will also light up on its own and bring up the clock like it does normally as if the phones being moved like the motion sense, which will stay on for a good second but as soon as I hit the power button to unlock it it flashes and goes right off. it seems like everything else works fine other than that the screen is not cracked in any way there's no discoloration or marks or anything like that with the LCD display and the touchscreen was working fine anywhere that I touched on it when it was letting me answer the phone. If anybody can help me and let me know what they think the issue is with it and what it would take for me to try to fix it or cost to have someone else repair it I would greatly appreciate it.
@adorkable_nicki
there is a lot going on and this will be really hard to figure out. From what I read I would suggest that you start with a new display assembly. An LCD display can have failed for reasons other than being externally cracked. Your phone had a pretty devastating blow delivered and you will really have to open it up and take a lcoser look at things. Here are the guides to work on your phone Motorola Droid Turbo 2
If you find things that are odd or don’t make sense you can always post pictures with your question. that way we can see what you see. Use this guide Adding images to an existing question for that
So even tho the picture shows up it could still be the LCD?
Nicki Monahan crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 277
