The Apple iMac M5521 is the slot-loading iMac G3 all-in-one desktop computers, produced between October 1999 and the summer of 2001.
iMac dv won't complete startup
After attempting to install updates i believe 10.2.4, it required a reboot but system just gets to the Apple logo screen and the timer wheel keeps spinning. I have left it in this state for hours never completes. I have tried all sorts of key start-up combinations: s, command-s, shift, cmd+shift+del+opt, v, spacebar, cmd+opt+o+f. never gets past apple logo.
i don't have OS disks. any ideas would be welcome.
thanks in advance.
crwdns2889612:0crwdne2889612:0 -1
If OSX is installed, restart the iMac while holding down Command S. When the text page appears,
Type: fsck -fy then press RETURN key (NB: there's a space between k and -).
You'll have to wait a little while the installed OS is scanned and repaired. When the repair is done you should read "The volume <<hard drive name >> appears to be OK" If you see "File system has been modified" retry the procedure (fsck -fy) until you see "The volume <<hard drive name >> appears to be OK" then type reboot and hit RETURN. The iMac should restart and boot a repaired system.
I have tried multiple holding keys at power-on each combination for about 25-30 minutes each try until my fingers cramped. i actually put a weight on the shift key and let that go for a few hours. All with same result. Apple logo screen appears, hard drive crunches and the little wheel spins and never gets to text display or desktop. thanks for the suggestion. i may have to buy a copy of osx tiger or try a ubuntu boot disk and try repairing from within ubuntu.
ronf57 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 835
