HX9360 can't turn on
I measure the battery about 3.8V.(F1 /R6 point).So I think the battery is fine.
But I push the button can't turn on it.But put into the cup can charge the battery.
So how do I to check the board or more action?
thanks
I have probably a similar issue. Who can find and change a battery here?
swat1230 your voltage maybe fine but it is not a good indication of your battery being okay. It is possible that your battery simply does not hold enough charge to supply the demand. I'd start with a new battery first, then re-evaluate. Check your switch circuitry etc. with your multimeter.
I'm having the same problem. Have you fixed it?
Thanks!
I have also checked the switch circuitry, which is fine. Additionally I have also connected an external power supply with 3.8V. Unfortunately it didn't helped.
I have exactly the same issues, battery power is still good. Have so. fixed the problem yet?
swat1230 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,361
