External storage options by Seagate, usually connected by USB, available in many storage sizes and form factors.
How to open Seagate ST90000U2-external hdd case & remove drive
hello,
This seagate case uses 5-point screws (torx plus?), the problem is i do not know what size so as to find the appropriate driver.
any help/ideas much appreciated.
Mike
You could measure the size of the 5star or you could be a set of the screwdrivrs.Size Inch point to point [in] Metric point to point [mm]
T1 .031 .81
T2 .036 .93
T10 .107 2.74
T15 .128 3.27
T20 .151 3.86
Looks like very limited availability :) http://www.traderscity.com/board/product...
and http://www.8starshop.com/en/12-in-1-comp... I am also sure that there are many more places that have a set of those. Good Luck to you.
I had a case like that; I believe I was able to remove the screws using a small flat screwdriver that was able to fit tightly enough into the screw head. Once I removed the screws, I replaced them with regular phillips head.
I can confirm that the screws for the casing of the Seagate ST90000U2 external HD are Pentalobe #6. You need a screwdriver PL-6 (Pentalobe #6) for these screws. I got a set of screwdrivers from a German company called Wiha, available on Amazon.
grskarpat crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 5,776
