The Samsung Galaxy Tab 2 10.1 is a 10.1-inch Android-based tablet computer and belongs to the second generation of the Samsung Galaxy Tab series.
Keeps turning off and on and won't stop
My Samsung Galaxy Tab 2 10.1 keeps turning off and on. You don't have time to do a factory reset because that's all it does is go off and on. Any suggestions? I have tried the off and on button with the volume button to reset but it doesn't stay on long enough.
crwdns2889612:0crwdne2889612:0 23
crwdns2944067:025crwdne2944067:0
I have a Samsung tab 3 v4.42.0 I hit it on the back and it works on me
XD
loo at the above comment
If you have your tablet in a case, that might be your problem. My tab a kept shutting down until I took it out of the case when I used it. It was simply getting too hot and shutting down because of the elevated temp.
I have the same problem...it appears when my batery is low ( below 20 %). When I plugged it on charger it stopped...i thing that I will return back to shop.
In my situation, it was the magnet in the case. Took it out of the case it's fine now
crwdns2934275:020crwdne2934275:0
Try disconnecting the battery . This is a common problem with Samsung tablets and is often resolved by just disconnecting the battery for a few minutes. This video is a battery replacement video but shows how to get into the battery and how to unplug it. You don't need to remove the battery . Follow the video only as far as the disconnect.
https://www.youtube.com/watch?v=Ow5T93uq...
Hope this helps
crwdns2889612:0crwdne2889612:0 8
crwdns2944067:016crwdne2944067:0:
Thank you very much. I'm sure gonna give it a shot.
I got my tablet to come on but n I w I have an android guy and it says that it's dowloading, Exec it has been doing it since last night. Please help
how did you manage to turn it on? I think i'm having the same issue..
My Tab 2 10.1 is doing the same I think. I turn it on and as soon as it loads it turns off and then back on again and continues to cycle like that until the battery has discharged. I can then charge the tablet and then when I turn it on the same cycle starts all over again. It will not stay on long enough for me to go to settings and do a reset.
I think your tab is on bootloop,
Try this..
https://m.youtube.com/watch?v=I-DoMvR3Uz...
crwdns2934275:011crwdne2934275:0
What is happening with the device Is that It's bootlooping, only thing you can continue to do try Is doing getting the device into the boot screen where you go to reset the device. Another thing that could be tried is new parts that could potentially cause the boot issue but most likely It's a motherboard issue with the device.
crwdns2944067:010crwdne2944067:0:
It will never let me get to the reboot screen. Is it best to just buy another one or does a motherboard cost less? I tried taking it to Best Buy but they always say there is no one there that can look at it right now. They suck! Lol
I would just buy a new one, motherboards are usually around the same price of the device.
Thank You very much. I love the one I have, so it looks like I'm just getting a new one.
My Galaxy Tab A was going to a black screen.... no buttons worked at all. I had it in a protective cover, and as soon as I took it out of the cover, it is now working fine. As soon as I put it back in the cover again... black screen! I don’t use a protective cover anymore :-)
I just saw another post, and it’s the magnet in the cover that is causing it. The protective cover I have is like a book, and when you open the cover and fold it behind the tablet, it displays a black screen and renders the buttons useless. As soon as you unfold the cover, the Tablet is operational again. Give it a try
crwdns2934275:05crwdne2934275:0
If it's the A7..I solved my issue….
Settings…advanced features… motions and gestures…
Now deselect the double tap on/off features…
This solved my issues..no reset needed..apparently when I open my case I double tapped my screen.. check and see if this works for you… Good luck and as a wise man once said….. Crush you enemies…see them driven before you.. and hear the lamentations of their women..(thank you Conan)
Dude thank you so so much! The advanced settings gig was definitely the hit! You're awesome sauce!!!???
What I found the problem to be was the power management chip. The tablet kept restarting. Go to the battery app and reduce the power consumption to medium. Mine has worked fine ever since. To change the power management chip would make the unit to expensive to repair.
Yes it worked.
I will let you know if this works or not. The only battery management I could could find was in the device maintenance so we will see if that did the trick.
if it keeps turning off you cant go to power manegment.
thats just dumb\
My android tab 10 max keeps turning on and turning off is there anything I can do to help it
Robin Harbin crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 114
crwdns2936753:030crwdne2936753:0 476
crwdns2942667:0crwdne2942667:0 205,151
