The ZTE ZMax Pro is identified by its black color, rear fingerprint sensor and its model name, Z981, which can be found under the rear case.
How to Remove & Replace Broken Screen?
How to repair remove a broken screen on a ZTE phone?
Can You Please To Remove My Broken Screen On My ZTE Phone Please...
All you need is some pry tools and the and a #00 Phillips screwdriver.
Phillips #00 Screwdriver
iFixit Opening Picks (Set of 6)
First take off the back of the cover using the pry tools
Then remove the Kapton tape ( it should be a yellow translucent tape )covering the fingerprint scanner flex cover
Unscrew the fingerprint scanner (mentioned above)
And finally, use the pry tool between the screen and the phone and go down the sides while simultaneously prying the screen away .
When you have the screen out, you can replace it by doing these steps in a reverse order
crwdns2886500:0Precision fixed blade screwdriver engineered by iFixit.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$5.49
crwdns2886500:0Thin prying tool for opening electronic devices. Opening picks are essential to open any iPad, tablet, or smartphone sealed with adhesive.crwdne2886500:0
$4.95
How to remove an replace broken screen face
Mona crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,768
