Device doesn't charge after display replacement.
Hey, I needed to replace the display of an S8 Plus. Unfortunately it doesn't charge after the replacement. The temperature is too low. I tried a new battery and the phone starts but still it won't charge and I get the same error that device temperature is too low. Any ideas?
Hi. I had the same problem for 2 s8 and s8+. Try to assemble the whole phones, including screws, without back cover and put it in charge. It worked for me, i hope it will do it for you as well.
Thank you! It worked for me too!
Thanks was helping to save my day. you really have to assemble before charging . superb
Charging port is most likely faulty. I take it you used a replacement display assembly which included LCD with frame and charging port with it?
I'm not 100% sure about this but the charging port model label mismatch from the phone model can cause issues e.g SM-G920I with SM-G920F for example.
No I had to take the original charging port, but I will try another one and tell you if it worked! Thank you :)
If you have a Samsung Galaxy S8 or S8+, there’s no foolproof way to prevent it from damage.  Just get it serviced from the professional. That’s it !
Because doing all things on your own cannot get it run in the proper way.
Regards,
Gadget Genie
Check to see if you have the NFC installed
elreparero crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 3,211
