Dulan Wijesundara check your power board for bad capacitors and check the fuse on your T-con board. A failed T-con board can be a cause for a non-working screen. Post some images of all your boards with your question so we can see what you see. Use this guide Adding images to an existing question for that.
Okay so since you do have the backlight that means your panel and your power board are most likely ok. That leaves you with possibility of a bad T-con board as well as a bad main board. Do you have a multimeter that you can use? Can you check the fuse on the T-con board and see if it has continuity and/or power?
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
2
crwdns2944067:05crwdne2944067:0
hey, did you find the solution? having same issue
crwdns2934271:0crwdnd2934271:0 עמי לווינשטיין crwdne2934271:0
yes.. it was T-CON board issue. i replace the T-CON board.
crwdns2934271:0crwdnd2934271:0 Dulan Wijesundara crwdne2934271:0
Which tcon board was it? Pic please to show
crwdns2934271:0crwdnd2934271:0 Emma Champagne crwdne2934271:0
@Emma Champagne
TVs only have one tcon board. The tcon board is the board that connects to the screen.
Depending on your model it may look like the one above with the red and yellow arrows on it showing the cables that connect to the screen.
Usually you can tell which one the tcon board is because the mainboard connects to it and it connects to the screen i.e. mainboard > cable > tcon board> cable(s) > screen
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
Had 2 vertical lines. Replaced with a new T-Con board. Restyle…No picture but had sound. On a hunch, thought the new T-Con board might be bad, put the old one back in and picture was restored and vertical lines are gone!
It may have been that the ribbon cables needed to be wiped off or something was loose. TV is working fine and it beats having to purchase a new one$$$
crwdns2934271:0crwdnd2934271:0 Diana crwdne2934271:0
