Engine won't fire could it be worn rings?
Won't start even with starting fluid. Good spark. Measured compression and got 30 psi. Rings ? The reeds also look ok. Not sure what's next
Hi Rich ,
Your compression is way too low . I like to see it at something close to a hundred pounds or better .
It will run at lower compression , but , along with that comes lower over all performance .
You could try a new set of rings and a hone ( necessary with new rings ) . But , if the rings are that far gone , I'd think a much better solution would be a next oversize piston set ( piston , rings , clips and possibly a new wrist pin bearing ) and a bore job to match .
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 424
