Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
crwdns2934591:02261crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Lines across screen during use following screen change
Hello,
Can anyone help me... ive changed the screen and this is what I am getting... screen seems to die after a few minutes... connectors are on properly... I’m thinking faulty screen
https://youtu.be/gQPriGecD1o
TIA
Rob
Hey Rob! That's quite the odd behavior! Usually that's a sign of the LCD connection being faulty, even if it's seated properly. I'd check the pins in the connections, both device side and display side. The thing to check for is dust/debris in the connection or bent pins. If everything looks pristine, and the device still behaves strangely, then I'd say it's an LCD issue deeper in the display, and you should seek replacement. Best of luck with your repair!
Rob Bear crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 34
