Won't power on - at all. What to do/replace?
School computer for student use was brought to me with complaint: running on battery-only, unexpectedly powered down. I charged with known-good outlet and power adapter for over 24 hrs. At first the magsafe light would alternate green-orange, later only a VERY dim green glow. Pressing the power button has no noticeable effect - no noise or light. I've reset the SMC numerous times; swapped the RAM around; tried with and without battery.
Condition: magsafe port is clean; some damage to the case - probably voiding Applecare - topcase is raised somewhat near IR receiver, bottom case has hairline crack near join of topcase to left of trackpad (damage appears old); power button is SLIGHTLY depressed (but has satisfying click feel when pressed).
From reading here, I'm guessing it may be the mag safe board or topcase - but I don't know which is more likely, or maybe something else.
Suggestions?
BTW, this site is awesome!
I replaced the MagSafe board and it's now working! Thank you.
I'd go for a new MagSafe Board, as it doesn't work, even when plugged in and battery removed.
See here:
MacBook MagSafe DC-In Board
Cheers,
deSteini
crwdns2886500:0Replace a broken or damaged MagSafe DC-in board for your MacBook with this part. This part connects the wall adapter power to the logic board.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$19.99
Thank you. I've ordered the DC-In board.
Swap in a new battery and try that, if not, I'd think the mag safe board.
David A crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 1,616
