Part of the 15 series in Dell’s Inspiron notebook line, the 3520 model was released on October 18, 2012. The Dell Inspiron 3520 is a 15 inch laptop that is both affordable and capable of meeting a variety of needs.
Why won't it boot?
Ok so I was just going about my business paying some World of Warcraft when out of no where I got an error window then my laptop crashed and won't boot. I couldn't see what error because it crashed before I could get a good look.. but it was one of the 0xc00000XX errors. I unplugged all usb devices took out the battery and ac adapter then held the power down for about 1 minute then plugged only the ac adapter in and it powers up with no display and I did try hooking up external monitors at both AVG and HDMI ports. I've also done all that but changed the ram with my other laptops ram and then turned it on but still have the same issue. the fan also starts up on high and my laptop gets pretty hot.
Edit: I can get into the BIOS by holding shift down and power button down for about 5 seconds. out of the BIOS I still have the same problem.
Edit 2: I ran a diagnostic on it through BIOS menu and it said everything was perfectly fine. after that I still had the issues but I had kept messing with it turning it on and off and it's booting up properly now. If it does it again I'll screen shot and post more details.
When you are in BIOS, do you see a display? If you reboot, do you see the Dell splash screen?
crwdns2957956:0crwdnd2957956:0crwdne2957956:0 crwdns2950251:0crwdne2950251:0
Yes the display worked fine in the BIOS.
If I had to take a shot in the dark, I'd wager its a bad hard drive.
Try booting to a linux OS, or use something like Hiren's BootCD or PartedMagic. You can see if it at least boots up with those, then you'll know that its a Software (windows) problem or the HDD. You'll also be able to test the HDD in Hiren's or PartedMagic to confirm its ok/bad.
If you're feeling adventurous and your other laptop has Windows 10 installed, you could also swap its own hard drive into the troublesome one. Windows 10 is pretty good at booting even if its suddenly in a totally different PC. Just make sure you back up your data, just in case any settings get screwy after it re-configures (not common, but always a chance). If it boots up ok, then its pretty likely to just be the OS or HDD.
I thought that as well but I hooked it up with another laptop and it was good. I also tried booting into a live cd and that wasn't working either. well I managed to get it back working.. not entirely sure how. my guess is that the diagnostic I ran got it working somehow? no clue but it seems good now.
Ashley Anderson crwdns2934231:0crwdne2934231:0
crwdns2959996:0crwdne2959996:0 669
