Lens says it's not attached properly
There's a message on my camera saying "cannot recognize lens attach lens properly" it's perfectly attached so I'm not sure what's wrong.
Your lens is probably damaged. Check the connections on the back of the lens . make sure they are not corroded
You may be able to clean the contacts with an eraser.
Good luck.
Wnen I said "damaged" what I really meant was, the contacts were likely dirty or corroded. My fix still works, but you can also use denatured alcohol and or Deoxit if they are really bad
crwdns2942667:0crwdne2942667:0 1,294
