Apex x100 Camera won't record
Everything about my drone works fine except for the fact that video and picture won't be recorded onto my sd card. The drone recognizes that the sd card is there, I've tried multiple different mini sd cards. The drone responds to remote commands and flashes lights when input is made, and I have visual connection from my FPV screen. I've opened up the camera and all wires are connected as far as I can tell. It just wont record anything, if you know what might be wrong please let me know
Did you check what format the card is in? I,me not sure what the drone requires I think it is Fat32. That is what most memory cards are
absolutely a hero here. i had no idea it needed to be in Fat32. i just thought ExFat was like the new standard for everything to use. was having the same problem and reformatting solved it!
My Warhawk drone won’t go past step 6 on setup &synchronization
Same here....everything calibrates except step six at the 45 degree turning...the lights won't stop flashing
It comes with its own memory card already
mine either, does the camera angle button work? mine does not change the camera angle and the one button take off does not work...
Reuben crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 401
