Won't power on or off?
The pulse l.e.d front panel stuck keeps flashing lights,But won't let me power on? Lights won't shut off? Won't let me connect to phone..Is there a way to factory reset it?
crwdns2889612:0crwdne2889612:0 18
crwdns2944067:020crwdne2944067:0
Hello to every one.. i have bought my Bluetooth headphone. i was very happy that it was playing my mobile's songs without wire.. but i didn't know what happened to it. when i press the power on button it remains power ON but when i release power on button my headphone again goes to shutdown
how will I do if my T&G radio failure to charge what can i do
How I can reset my iBall pulse bt4 headphone.keep flashing but doesn't on off....what can I do........
Power button would not off. Plz help me
I have got this headphones. I am not able to shut it off. The light is on. How do i turn it off??
crwdns2934275:015crwdne2934275:0
@tweetjoker1112 ,Thomas, Had no luck finding info. on(2boom Pulse Bluetooth speaker) posted what I did find below. Good luck.
JBL Pulse 2 Reset procedure: Turn on the device by pressing the on/off button for about a second.
Press the "Vol - " button and the "Bluetooth" button together for more than 7 seconds.
The unit will display Red, Green, Blue light and go into power off stage, but with the on/off light and the light symbol lighted up.
The unit is now reset to factory settings.
Switch the Pulse OFF by pressing the on/off button for about one second.
You can now turn your device back on and it will be reset to factory settings.
UE Boom Reset procedure: Turn on your Devive.
Hold down the volume down button and the power button at the same time until you hear a sound.
Your UE Boom will then turn off.
Turn it back on and try to pair it with your device again.
Note that doing this many times in a row may harm your speaker, so refrain from doing this more than once or twice.
How do I restore my JBL Pulse to factory settings?
UE Boom Troubleshooting
Hello
The led light does not turn on when I turn on my bluetooth speaker. Also, Bluetooth is already paired to my phone but cant hear... It doesnt works
The 2boom power button will not turn off; the 2boom speaker is still on!
Mine had the exact same problem and it was in demo mode somehow.
TO EXIT DEMO MODE ON JBL PULSE 2:
1. plug speaker in and it will turn on
2. hold the JBL connect button and the volume + button for 10 seconds
3. turn off and unplug
then it should work normally again!!!
crwdns2889612:0crwdne2889612:0 7
That corrected my problem, thanks. Now I have a backup Bluetooth speaker. I purchased a Bose speaker since and am very happy with how seamlessly it works with my Android and iPad. Thanks again for your very simple solution.
When I did this it turned white, but I couldn’t turn it off. Then turned green and made a noise after I unplugged it.
Tanx a lot, it really worked
Worked for my QFX H-254 Bluetooth headphones too. Thank-you.
How do you do it on a JBL flip 3SE
Open the device. Try disconnecting and reconnecting the Body Control Module (BCM) connectors.
Worked for me!
On a JBL speaker pressed the Bluetooth and plus buttons for a second an finally the speaker turned OFF.
how do I fix my stuck power button on bluetooth
Thomas Blair crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 54
crwdns2942667:0crwdne2942667:0 109,933
