The root cause: The circuit on the buttons panel of the right corner of the TV is messed up.
The solution:
1) Disconnect the power and all other cables from your Samsung LCD TV.
2) Place the TV on the carpet facing down
3) Remove all the screws from the back panel. This is easier said than done. You need the right screwdriver. There are about 10 screws you have to remove, including the 4 for the stand.
Caution: There is high voltage inside the TV. So be careful what you touch.
4) Near the TV buttons on the right corner, there is a white+blue wire that connects from the panel to the Infrared receiver circuit. Here is a picture of the same for your reference. DISCONNECT THAT WHITE+BLUE WIRE.
https://photos.app.goo.gl/zMLL1DjSwGJD7h...
NOTE: This will stops the button panel from working. But your remote will still work and you can use it to change channels, volume ..everything.
If this solution worked for you, kindly send me a Thank you note at vpkamath@gmail.com
I like to know when my efforts help somebody.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
0
crwdns2944067:09crwdne2944067:0
Hi, What is the model number of your Philips TV?
To add to @dabrien 's answer, there may also be a channel up/down button on the TV that you may wish to check as well.
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
You might want to check out You Tube, they have videos assdressing this problem
crwdns2934271:0crwdnd2934271:0 modura66 crwdne2934271:0
I have an LG flat screen TV that keeps going up in channels and was doing the same thing with the volume but I did finally get it to stop doing that just can't figure out how to get it to stop changing channels on me and I need to know what or how I should fix it , like I said I did get it to stop going up on the volume by pryin the volume buttons out but it doesn't seem to be working on the channel issue please help me in possibly fixing the problem , where I don't have to take it and have it fixed , opened to suggestions
crwdns2934271:0crwdnd2934271:0 Samantha crwdne2934271:0
Hi @savagemustang ,
Have you tried removing the batteries from the remote control unit to see if the channel movement stops?
I’ve been having the same problem for a few years. I determined today that it is related to audio sounds. When watching a movie with high pitch sounds it was causing the channel to change, menu to pop up, etc. Rewinding the movie it was happening every time. Loud screeching sound.
Just need to see if there is a fix.
crwdns2934271:0crwdnd2934271:0 Bobby crwdne2934271:0
crwdns2934275:04crwdne2934275:0
