What are the chances of corrosion on logic board
I dropped some green tea on my table and it went inside the laptop via the memory card and usb chord slot.
I had a keyboard cover on so that was saved. I instantly switched it off, wiped the external water and tried to get all the water out. I then took it to the apple service center and they removed the back cover to find some other places with a few drops of water. We cleaned that with cotton and he then switched it on to check if it was working. It was.
I kept it off for the entire day and checked the back panel again, as guided by the genius, switched it on to do the hardware test. It worked fine even the charger was working. Since then, I have kept it to dry for a 36 more hours.
The service center was not accepting it for a diagnosis to clean it internally too. (Don't know why).
Since it was working they said get it back in 3-4 days for a check.
My only question is what are the chances of corrosion. The second time I opened the back cover, there was no sign of remaining liquid or corrosion (8 hours later may be).
What are the chances of corrosion? If there is any, can cleaning it up with alcohol also prevent the corrosion from coming back in th future.
Update 1
I went to the AAPS, and they opened the laptop. There were no visible signs of corrosion. They said everything looks good and I should try using the laptop after 72 hours of the spillage. Also image attached of the logic board.
I have no skills in cleaning the board and AAPS refused to do it. Image below.
Should I take it to a non-authorized centre?
No signs of corrosion on the ports where the water seeped in from too.
crwdns2942205:01crwdne2942205:0
At this point I think you'll just need to inspect the logic board once and awhile to be sure. I don't see any staining so there is no single spot to touchup. Don't forget there is the other side of the logic board too. But as you stated you had a keyboard cover I would say the risk of something getting inside from the top is not likely.
Take is as a good sign! Just be careful in the future.
crwdns2934271:0crwdnd2934271:0 Dan crwdne2934271:0
