Power button isn't work after screen repair
Hi
Plz help me
Only sleep/wake function isn't working
And i can't find option lock unlock in Setting
ios10 ipad mini4
Thanks
Hi
Plz help me
ios10 ipad mini4
Thanks
Had the same problem before i noticed the small cable that needs to be soldered onto the new screen. It has 6 connection points, and after transferring and soldering the cable, the on/off button worked perfectly.
Sounds like there is a possibility the cable for the sleep/wake button is not connected properly. Could you please send me the model number? Thanks!
model number A1550
When you put the device back together, (assuming you changed the screen) did you double, triple check the connectors? Made sure none of them were damaged in the opening process? If there is no visble damage, I would suggest a power button replacement.
Hello.
Thanks for responding.
I honsetly still have the same problem even though i cover the sensor after transfering it from the old digitilizer the model of the ipad is A1550
a flex cable in the old screen beside home button in left side :)
make sure you but it in new screen :)
that.s it :)
The new screen must have sleep wake sensor, otherwise power button will not work. Check https://youtu.be/r2pwiSmUB30
crwdns2942667:0crwdne2942667:0 4,747
Does the slide to power off screen appear when you hold the power button while the iPad is on or unlocked?
If yes then the issue is linked to the home button flex. I don't remember how the home button is set up for iPad Mini 4 but it it should have touch ID and hall effect sensor chip (that controls smart cover functionality, if it's broken the iPad thinks the cover is closed and disables the lock button press) on there which may need to be transferred from the old home button to the new one or if it's separate you should be able to transfer from old digitizer to new digitizer.
crwdns2934271:0crwdnd2934271:0 Ben crwdne2934271:0
