Won't shift into gear.
I installed a rebuilt transmission from a reputable company along with a used (freshen up with new seals) transfercase and new standard torque converter. I put a quart in the torque converter before install, 6qts in the transmission before startup. I ran the engine till warmup checking the fluid in the process. I moved the shifter through all the gears and back. When i went to put it in park sounded like the transmission was rotating because of the grind on the parking pin. My question is the truck does not shift into gear either forward or reverse could it be the transmission or transfer case? Do i need to readjust the TV cable? I double and triple check all connections.
I having the same exact issue but I got it to move when in 4 low is this transmission or transfer case
crwdns2934271:0crwdnd2934271:0 Brennen crwdne2934271:0
