Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
crwdns2934591:02690crwdne2934591:0 crwdns2934593:0crwdne2934593:0
iPhone 6S can't restore error 6 or error 9
Yesterday one of my customers came to me with an iPhone 6s that changed the LCD by himself. After replacement the battery started drain faster than usual, I told him that it is not battery problem but LCD problem and need to be replaced again. He didn't want to pay for other LCD and he insisted to change the battery. This didn't solve the problem and after 7 days of use phone stack on apple logo and started boot loop. then he left the phone charging all night but it didn't help, his last action was to restore the phone but it failed. Now I have the phone and every time I try to restore I see sometimes "error 6" and sometimes "error 9". Does this phone has motherboard issue? Has someone come up against same situation? I would appreciate if someone could help me, thank you!!!
Update (11/25/2016)
i checked the motherboard by myself with a microscope, i am not so experienced but nothing unusuall and no missing parts near the FPC connectors, but when i push the power button and phone start and try to boot this part of the motherboard get really hot
There is the Memory Chip in this part of the motherboard and i think that this phone is shorted in there. Can someone tell me if this phone can work again or not?
crwdns2944067:010crwdne2944067:0
Thanks for your time. In iPhone 6s what screw hole is most sensitive and can cause this problem. I have a microscope and i will inspect the board near the LCD, battery, camera, digitizer connectors and i will replay here. Thank you again for your help
But I tried in a different pc and the same error.
Exactly the same situation and the 3u tool below it self is giving us 6 where as the itunes is giving me 9 - between the 69 and the customer DIY'n I'm clueless as to what do do next.
1) ChargerPort verified by disconnecting/reconnecting battery & plugging in. 2) Phone charges to 'Connect to Itunes,' mode
Don't know why but I have the jailbreak blues, asin, I think this phone was previously jailbroken and in 3u/itunes exactly at firmware part it crashes and loops back to 'Connect to Itunes,' error
That shield covers the CPU. It is normally warm but not hot when the phone is idle. The memory chip is on the underside of the logic board where the SIM card reader is.
in this model CPU and memory are in the same Chip. This part was not warm but really hot, now I tried to restore from DFU and I can only see the connect to iTunes image on my phones screen
crwdns2934275:05crwdne2934275:0
crwdns2933315:06crwdne2933315:0
You could try to restore your iPhone with 3uTools.
http://www.3u.com/tutorial/articles/180/...
Is this a freeware tool or not?
This is a freeware tool, but reliable. i am using it
Are you able to get all of your data before doing the restore if you don't want to lose your data forever?
tried using 3utools I still get the same error
I tried but there are another errors
Could be U2 IC charging chip gone bad.
To test this first unplug battery. Plug battery back in. Don't press power button. Plug charging cable in and see if iPhone turns on itself. If not then chip is most likely bad.
And yes this is caused by the user of the iPhone using cheap chargers or car chargers with cheap iPhone cables that are not MFi certified.
I highly doubt the LCD is causing this problem. It is probably related to the customer trying to replace it himself. He may have knocked off one of the surface-mount components near the FPC connectors (battery, LCD, Digi, FCAM).
This logic board needs to be inspected under a microscope or 10X loupe.
Depending on what you find, it may need to be repaired by someone who can do micro-soldering.
Can you post pictures?
crwdns2944067:07crwdne2944067:0:
maybe long screw damage D:
Hi @Gigabit878. Yeah, I thought about that also...let's hope not for the customer.
@ johnfl21. The two standoffs that can cause failure are the two at the bottom of the bracket holding the connectors. See the image below...
iPhone 6 Plus LCD and Digitizer Replacement
It doesn't seem to have long screw damage. I can see the holes in the microscope and i see no damage.
crwdns2934275:02crwdne2934275:0
I heard somewhere that you should remove lockdown directory on your pc (windows) but i can't remember what error numbers this was related to.
I tried to restore in three different pcs but i have the same result
you can try to restore without display and in dfu mode. Have read somewhere that you can also try to plug something in the audio jack then restore.
Plugging something (headphones) into the audio jack of the laptop and restoring the iPhone 6s with the latest iOS Firmware (11.2.6) really worked! Thanks!
que hago en iphone 8plus no tiene conector para auriculares
My real story iphone 6s won’t restore error 9, after long long testing and changing Ices , problem is; in a rainy day came little drop under the shield cann’t see it between U2 and ram chip, toke the shield off clean it all , then went restore perfect.
Put your iPhone 6S into recovery mode and then restore it with iTunes or try Joyoshare UltFix to fix iPhone error that occurs when restoring. It can not only fix such errors without data loss but also restore any iOS device in a quick way.
johnfl21 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 50,865
