Released in 2013 by Garmin, the Garmin Nuvi 2597LMT is a Bluetooth GPS device that has a 5" (12.7 cm) touchscreen.
What should I do if my battery won't charge?
My battery isn't accepting a charge at all, and the cable is plugged in.
Student, being worked on by hardworking students
If the device is not charging while the the cable is attached to both a power outlet and the charging port on the device, the battery may be fairly easily replaced by unclipping the old battery from the motherboard and replacing it with a new battery. If this does not solve your problem, you may need to replace the micro-USB port located on the motherboard which requires more work.
Patrick McNett crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 823
