Why won't the juicer start?
The juicer in plugged in and on, but when u flip the switch to start juicing at either the low or high speed setting, nothing happens.
Thanks for your question!
This is a common problem experienced by users.
One reason it might not turn on is that the safety locking arm is not engaged. If this is the case, you can engage the locking arm by snapping it into the two grooves on either side of the juicer cover. Once it is securely fixed in the vertical position, you should be able to turn the juicer on.
Hope this helps! If you are still having difficulties, check out the troubleshooting page for other possible solutions.
It's tough and worked to keep going for extensive stretches. https://moonshinejuicery.com/best-juicer... The additional channels ensure you get the best nature of juice without froth or any filaments hanging about. It has an enemy of dribble structure which ensures there's no spillage and your kitchen remains clean. With regards to cleaning, you don't have to stress over any trouble. Cleaning it is as simpler for what it's worth to utilize.
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 6,775
