A touchscreen GPS released in February 2012 by Garmin with custom position of interests and junction view. The screen size is 4.3" diagonally with 480x272 resolution.
Why Won't My Touchscreen Work?
My device will turn on but when I press the screen to make any commands I can not prompt any response. Please help.
There are three possible problems that are associated with an unresponsive touchscreen. They are listed from easiest to hardest to complete.
Dirty Screen:
  • If your device has a screen protector, remove it
  • Spray a bit of water or formulated spray onto a microfiber cloth.
  • Wipe thoroughly.
  • Using another dry microfiber cloth, immediately dry the surface.
  • Replace the screen protector with a new one if desired.
Resetting the Device Without Using the Screen:
  • With the GPS unit off, press the bottom right hand corner of the screen. Turn the unit on while maintaining pressure in the bottom right corner. When you see a prompt asking, "Do you really want to erase all user data?", you can release your finger and select yes.
  • If the bottom right of the screen is unresponsive then please refer to the broken screen guide.
Broken Screen:
  • If your device screen is still unresponsive after following the following guides above please refer to this guide for replacing a broken screen
Nathaniel Williams crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 603
