Repairs for most tablet computers. Because of their small size and frequent use of adhesive, tablet repair is often more involved than laptop repair.
Why won't my ematic egq780 tablet wifi stay signed in?
I have a ematic EGQ780 7.9 16gb tablet. The wifi keeps going in and out. First it say's that it's saved. Then it starts scanning or searching all over and then it says there's a problem with the authentication problem.. Why is it doing that and how do can I fix it?
When I had slow download speeds, my tablet, iPad ,printer, and computer would disconnect . This would happen when I was using 2 or more devices and had slow download speeds. If you have DSL service it common for the speed to be slow. To check your speed go to the Internet and type in speed test. I have a free app called ookla. It is easy to use. If you have slow speeds(1.5 mpbs or less) you can check telephone and cable connections to make sure they are tight. Sometimes the routers slow down when they get old. I finally solved the problem by having high speed service installed. It isn't much more expensive and 7 devices can be used at the same time. I hope this helps you. Good luck!
shashamaxime crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 125
