Why can't I answer my phone?
Phone rings and i swipe right, left, down, etc...have not been able to answer phone ever since it arrived....
This took me forever and i still don't know how it happened but, go to you SETTINGS, then go to APPS should be under the category DEVICE but it shows all the apps on your phone, then scroll down to the app that you use to make calls should simply say PHONE (side note make sure this app is set to DEFAULT), click on it and scroll down to where it says NOTIFICATIONS, there make for sure your BLOCK ALL option is off and at least TREAT AS PRIORITY or ALLOW PEAKING option is ON... Hope This Help You Or Someone Else... It's What Happened To Mine I Don't Know How And It Sucked...
VERY GOOD. My Blu G60 manual was useless to solve problem
Check your call forwarding, it may be on
I think you should check updates for your phone and if it doesn't solve the problem, then the problem is in the phone's firmware. try to contact tech support.
I havethis problem from time to time - i swipe to answer and it just continues to ring - does not pick up. Other times - no issue.
crwdns2942667:0crwdne2942667:0 6,194
I have this problem too
crwdns2934271:0crwdnd2934271:0 satanismycat crwdne2934271:0
Can't answer phone when someone is calling
crwdns2934271:0crwdnd2934271:0 Victor Lopez crwdne2934271:0
